SL/R129: R129 320SL no accelerator response
any one experienced no throttle pedal response on 320SL just stays on tick over,if switch off and on a couple of times it will be ok and rev as normal ,,had mass air flow few 2 years ago ,thanks in advance
Bad accelerator?
Failing/failed accelerator is a common fault of some model years.
Bad wiring insulation was primary failure point for early to mid '90s medcedes.
Failing electronic throttles are another failure point. Look on here for 'Victor' for repairs to your electronic throttles.
