SL/R129: Opinion on this SL that I've just acquired
Hi Folks,
I've just bought this classic R129 at auction. I was wondering what people thought of it ?
Any things to look out for??
And any likely preventative maintenance issues, or other tips, etc???
Greatly appreciate any feedback,
Cheers,
Horgand
https://www.carandclassic.co.uk/auctions/1992-mercedes-benz-sl300-41DE7n
Cheers,
Horgand
Horgand (12-21-2021)
You have acquired an OLD OLD convertible. Known failure modes are:
A/C evaporator --'running crack' in tube sheet requiring replacement a 20+ hr job
A/C compressor damaged from low charge
Wiring all dash, engine,front end wiring insulation will need replacement- another 40 hour job
Hardtop all hydraulic cylinders (12) require re-sealing another mega hour job
Hardtop window plastic yellows and turn stiff and cracks
Heater multi-valve failure
suspension hydraulic cylinders require replacement
the rest of the typical wear/replacement parts are routine.
Horgand (12-22-2021)
94 SL320 98 SL500 99 SL600 07 SL55
Hi Folks,
Cheers,
Horgand
https://www.carandclassic.co.uk/auct...z-sl300-41DE7n
Cheers,
Horgand
Change all fluids to begin with. Can be a great project car if you're DIY. Just take on one issue at a time and bring it to new condition.
Horgand (01-05-2022)
R129 SL55 AMG & W208 CLK55 AMG
Congrats on the purchase.
As others have mentioned, first get all fluids changed and see if there are any leaks.
And have a close look at all the control arm bushings and suspension parts.
Next up is cooling system ( hoses, Thermo, radiator, fan and pump )
If I was offered a decent deal to px for a 500SL instead, would you reckon I should take it?
All advice much appreciated.
