SL/R129: SL500 fuel leak
SL500
SL500 fuel leak
Hello all
My car is a 1999 SL500 with 44k miles.
question,
recently bought it and put about half a tank. Drove the car a bit and then put full tank.
since then there is a smell of gasoline in the garage.
The description above is similar to what I had couple of years ago with my mustang. The gromet between the fuel tank and the hose needed to be replaced. Every time I put full tank fuel started to leak from the rubber groumt.
is this the same case with the SL?
or there is a leak other place?
notes: the floor is clean and I can’t see any fuel on the floor.
engine run smooth. No warning lights?
any ideas or thoughts where to start looking?
thanks in advance
meir
question,
thanks in advance
meir
SL500
Update
I found that the leak comes from the pump.
any one knows what is the pump model number i need to search? same question regarding the fuel filter?
any recommendation for third party or OEM only.
any advise will be great appreciated
SL500
Thank you. That help.
I was wondering where can i find the serial number provided above.
any recommendation for showing Manuel i can buy on line?
thank you in advance
go here and enter your vin: https://mercedes.7zap.com/en/us/fg/car/
pick the AB one, then go to fuel system > fuel pump package. There you will find the right pump and filter part numbers for your car
