SL/R129: door window rattle
1998 Mercedes SL500 245,000 miles
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
My door windows rattle when closing the door. Might this be a common problem for the r129? is there something i could read to figure out the rattle, list of parts needed maybe?
please help
thank you
please help
thank you
Pulling off the door panel to get a visual may help also if you see nothing holding up. It may need some cleaning and lubrication on pivot points. The window tracks get real dusty, scrub with a tooth brush, blow out as much dust as you can. I lube window tracks with some spray silicone, not much though.
94 SL320 98 SL500 99 SL600 07 SL55
There should be a piece of foam rubber between the glass and motor attached to the motor plus the regulator may be sloppy too It can be a real battle to quiet those doors.
