SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: 2001 SL 500 Vacuum Leak
Old Dec 5, 2022 | 11:43 AM
SUHAIL's Avatar
1986 190D 2.5 (W201), 1999 SLK230 (R107), 2000 S500 , 2001 SL500, 2005 G55 Grand edition 327 of 500
I there anywhere I could find an engine diagram of all vacuum hoses, the car is over 20 yrs old. Still has original tubes, has been driven 49,000 miles. The check engine came on in June of 2021, I had it checked, was told there was some vacuum leak somewhere, the light was reset and the car was fine till yesterday when the light came on again same issue.
perhaps someone could guide me
Old Dec 5, 2022 | 03:01 PM
mahunt's Avatar
1997 MB SL600
My vacuum routing guide is located on the cover of the electronics box.
Open the hood and look for the rectangular black box at the passenger side base of the windshield.
Old Dec 6, 2022 | 06:03 PM
BenzBopper's Avatar
06' Audi Quattro, 00'SL500
What code is your car showing? One common vacuum leak is the little rubber hose connecting to purge valve, it splits on the end causing it lose it seal.
Old Dec 6, 2022 | 06:57 PM
SUHAIL's Avatar
PO442 if anyone on this forum could elaborate on it.
Old Dec 7, 2022 | 01:57 AM
Ahmed's Avatar
R129 SL55 AMG & W208 CLK55 AMG
Major Evap leak, read post #3 and replace the hose. That's what i did on my 99.
Old Dec 7, 2022 | 06:36 AM
SUHAIL's Avatar
Is this what you mean?
Old Dec 7, 2022 | 08:48 AM
BenzBopper's Avatar
Read this post, every code you'll ever need.
https://www.newcougar.org/threads/engine-codes.105913/
Replace your gas cap first, after opening and closing the seal on the cap wears out too causing a leak there also.
Old Dec 9, 2022 | 05:01 AM
Ahmed's Avatar
Just dug out an old video and realised it was a slightly different code. Sorry.
