SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: r129 light relay
Old Apr 10, 2023 | 01:49 AM
hai123's Avatar
500sl 1992 5L
r129 light relay
Hey all,
I have a problem with the lighting in the car, at first some of the lamps on the left side of the car did not light up like the road light in the back and the lamp near the headlight also on the left side in front, after some inquiries someone told me to check a relay behind the fuse box. I took it out and it looked fine, I sprayed some contact spray and put it back, from that moment on as long as the car is off the lights are on, but as soon as I turn the switch everything goes off and doesn't turn on, I must have done something wrong with the relay. What could be the problem and if there is a diagram of this relay that I can check if it is working?
Thanks.
Old Apr 10, 2023 | 08:13 AM
mahunt's Avatar
1997 MB SL600
Sounds like a grounding issue.
Old Apr 10, 2023 | 09:07 AM
hai123's Avatar
500sl 1992 5L
Can you direct me where to look?
Old Apr 10, 2023 | 10:18 PM
mahunt's Avatar
1997 MB SL600
Not specifically and the original cars with the old style fuses are know for electrical issues.
Old Apr 11, 2023 | 06:21 AM
AndreasHannover's Avatar
SL600
There is no relais for the lamps, but there is the "Lampenkontrollgerät" (sorry for the long German word).It is known for breaking some solder joints and then exactly what you describe happens. It is the long black thing at the outside of the box, dont buy an other one, they are as old as yours and it is not a question of if they break but when.
Good news: It is an easy repair, disasemble them and resolder the broken solder joints and everything will work again.
