SL/R129: Flashing Gas Light/Fuel Smell
About a week ago, I noticed the smell of gas, nothing crazy just a hint. Then I got to my destination, turned car off for about 3 minutes. Turned back on to depart and about 30 seconds into the drive the gas light started flashing. No sputtering, nothing strange just flashing. I turned off and back on and nothing. Drove just fine and has not done it since. No gas smell since. Any ideas where I can look? Gas cap seems new. Nothing leaking under car.
Best,
SuperSL
You're eventually gonna get a Check Engine Light come on with the P0173 Fuel Trim Malfunction.
So, first check your gas cap and see if it's leaking vapors.
Then do a vacuum leak test on your fuel lines. Do you know any shop that can do a smoke test?
Should I be concerned or was it just a hiccup?
