SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Antenna replacement
Old Aug 12, 2023 | 12:27 PM
Rjroller's Avatar
2002 Sl500
Antenna replacement
Had to replace my worn-out Antenna gromnet on my 2002 SL500 since my antenna popped out. The top one is the original one. Purchased the bottom one online and it keeps popping out my new gromnet. Where can I purchase an antenna with the same rubber washer like my original one? Or any other suggestions?
Old Sep 1, 2023 | 12:05 AM
kamil.kniczek's Avatar
G63, GLE 300d, SL500 (R129), 560SEC, 560SEL AMG 6.0, SL600 AMG Japan (R129 440HP)
the new one doesn't have any thread on the bottom screw? the black rubber on the old one is a part of sleeve in which the original antenna thread should be fitted.
if your old Antenna popped out with that black rubber then you need somehow to get that rubber to be attached to the sleeve again. after that the old antenna should be ok.
