SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Ball Joint???
Old Oct 7, 2023 | 11:36 PM
dug320's Avatar
1986 420 SEL and 1997 SL500
Ball Joint???
How much vertical play should there be on a loaded ball joint on this model? My '97 has a bit of a low speed front end wobble and an odd (it does not happen all the time) pull to the right. With the car in the air and a load on the control arm the front right tire does click and moves slightly when pulls and pushes are done with my hands in 12 and 6 position. On a Camry I would not worry.
I cannot rule out tires but they are on back order.
