SL/R129: Any that have cut open the wiper, combination, N10/2 relay? Part no 129 820 10 26?
I found this picture online where they have cut the top of the relay.
Any here that have or knows if you can open the relay down by the red line i have drawn in the picture at the bottom?
I am quite sure there is several "dry" solder points on the circuitboards inside the relay that i need to re-solder.
The malfunction on this relay began with the park light in the right side headlight would not come on sometimes but nort often.
Then the rear window heter stopped working.
But now the right side turn signal is constant lit so i have to disconnect the negative battery cable every time after i have used the car.
Off course there is no problem for me to cut the top off the relay but i would prefer to pull it out from the bottom if possible so that is why i ask.
Here you can see that the top of the wiper, combination relay have been cut off.
Any here that have open/cut open the relay further down where the red line is?
