SL/R129: Resistance too low
1996 sl 500
Resistance too low
I have a 96 SL500. Car runs fine. Any help figuring out what the following means? Thanks in advance.
However, after running a code reader, I am getting the following under TCM - Transmission Control Module
120 Resistance Too low. (the accelerator pedal value of the engine system is sporadically implausible) or (the front right wheel speed of the traction system is sporadically implausible)
121 Plus, engine system is sporadically implausible or the front left wheel speed of the traction system is sporadically implausible
Plus, 118 resistance too low - the right rear wheel speed is sporadically implausible - 119 Same with rear left.
1998 SL500,2011 GL550,2009 ML350,past 1995 E320 Cabrio ,2005 ML500,2006 ML500,1996 SL500,1972 280SEL
pictures of codes
What dash lights are on?
dash lights
This is first year for ODBII
So code should start P0XXX and they are fixed by the ODBII specs
118 & 119 are coolant sensors issues
P0118 Mercedes-Benz Code Meaning, Causes, Symptoms, & Tech Notes (engine-codes.com)
P0119 Mercedes-Benz Code Meaning, Causes, Symptoms, & Tech Notes (engine-codes.com)
120 121 are throttle position Sensor
P0120 Mercedes-Benz Code Meaning, Causes, Symptoms, & Tech Notes (engine-codes.com)
P0121 Mercedes-Benz Code Meaning, Causes, Symptoms, & Tech Notes (engine-codes.com)
Now if they start with a different letter it means different things.
