SL/R129: Problems with the blower motor and ac
The next thing I might do is buy a new regulator and see if that fixes it. There also seems to be a problem with the holder that holds the motor in place. If there is anything I can try to fix it or find a suitable fix let me know i’ll try it out.
The last thing is that there is no AC. I’m not sure if that happens because there is no blower motor but that’s an issue I think there is.
In my experience, over time the motor current gets higher and higher due to broken bearings. First it no longer runs at full power because the regulator is cutting out, then later the regulator burns out. I would install an old, good motor with an old, good regulator, the new parts from the accessories are usually bad.
I secured the motor with two cable ties, but the lower bracket has to be modified to do this.
