SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Vacuum diagram for ac does not match online diagrams
Old Sep 8, 2024 | 08:31 PM
carboy2800's Avatar
SL55 AMG
My 99 SL600 does not blow air from the center vents. On the vacuum box in the engine bay, I have the grey line which is the main supply going into the box and then 3 going out into the car. I have 1 green and 2 red. The green line is for the center vents but what do the red lines go to? This is the only diagram I can find, and it only shows 1 line going into the reservoir in the car. If I remove the 2 red lines from the vacuum box, air blows from the center vents, but not the sides. As soon as I plug the 2 red lines back in, no air comes out of the center vents but again blows from the sides. I assume something off of the red lines is leaking, but not sure where they go. If I apply vacuum into the green line, the center vents open. Anyone have a different diagram?
Old Sep 15, 2024 | 10:01 AM
Eiderdown's Avatar
1997 SL320, 1972 TR6, and 1981 Euro 230CE
If you provide your VIN number I might be able to pull up the right diagram. I've noticed on mine that pressing the air distribution button on the climate control panel (up-down-center) has results that are quite confusing. What happens when you press either the heated or non-heated buttons for the center air vent?
