SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Soft Top Control Module
Old Dec 23, 2024 | 08:18 PM
hankthebald's Avatar
I have a 2000 SL 500 and I am pretty sure the soft top control module isn't working correctly. Are there any recommended people who repair them or is it better just to bite the bullet and get a rebuilt one.
Amy recommendations would be appreciated.
Thank You
Old Dec 23, 2024 | 08:26 PM
djayanthan's Avatar
Reach out to Top Hydraulics in Oregon. They are experts in convertible tops and our R129 platform's convertible hydraulics/mechanism especially. They are very helpful over the phone as I've had long conversations with them about the specifics of our cars and they were happy to answer and very detailed in their responses. Here is their website: https://tophydraulics.com/
Old Dec 26, 2024 | 02:22 PM
I called top Hydraulics and they don't deal with the electronic control modules. I have found some on ebay and a repair service advertised on ebay and on the web but have no idea to the quality of these parts or services.
Old Dec 29, 2024 | 12:29 PM
vesiadog's Avatar
1998 SL500,2011 GL550,2009 ML350,past 1995 E320 Cabrio ,2005 ML500,2006 ML500,1996 SL500,1972 280SEL
ebay “thebenzgarage”
Reach out thru ebay to my son “thebenzgarage” he usually has them on the shelf. thanks
Old Dec 30, 2024 | 09:50 AM
Thank you I emailed you son.
Old Dec 31, 2024 | 01:27 AM
K.G_08's Avatar
2000 E320
What issues are you experiencing?
Old Dec 31, 2024 | 08:32 AM
The roll bar doesn't go down, I can have someone hold the down button and compress it manually, until it lock and the switch is made. once the roll bar is down the top doesn't work at all.
I have had Top Hydraulics rebuild all the Hydraulic cylinders and the pump. 3 years prior to the top failing to work.
The top was working correctly until I stored the car for the winter 2 years ago, when I went to start the car the battery was not only totally dead but the battery tender was dead as well. I don't know how long the car was without power, and when I replaced the battery then tried to start the car the starter solonid welded closed, so I had to disconnect the battery to stop the car from cranking continually. The top has not worked since
I have tried the window travel reset, resetting the roll bar in the up position. I have tried manually putting the top up and down. Nothing works, not the tonneau cover latches or any other movement. The pump runs and has pressure.
