SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Running on 4 cylinders only
Old May 27, 2025 | 07:10 PM
RustyBullets's Avatar
’91SL500
Hi, my SL500 1991 R129 is only running on 4 cylinders. Changed coils, rotors, tested input leads, and still no joy🥲Any clues??? Thanks in advance!
Old May 28, 2025 | 08:24 AM
darraghn's Avatar
500SL 1990 R129
I have read before that EZLs often fail on one bank first. Good luck with the diagnosis. Hopefully it's not the EZL as they are expensive.
Old May 29, 2025 | 09:03 AM
bttucker's Avatar
2001 SL500, 2017 GLE350
So if I'm correct that you have the M119 V8, check both distributor cap and rotors for carbon tracking (inside is most common). Replace cap and rotors if you haven't ever...sorry they're costly, buy quality.
Old May 29, 2025 | 09:06 AM
bttucker's Avatar
Sorry, forgot to mention you have two coils as well to check.
