SL/R230: chrome exhust tips
Old Mar 28, 2005 | 10:35 PM
tiggerfink's Avatar
SL500 and A-CLASS
chrome exhust tips
I got this picture from bollar's post. Is the inner part exhust tips suppose to be chrome? The inner part of the exhust tips look bronze. Look at the redarrows in the picture.
Old Mar 29, 2005 | 09:50 PM
doltmo's Avatar
2006 Gallardo 6-speed, 2005 SL55, BMW X3
Your arrows are a bit hard to see.
As I recall, the exhaust tip slides over the tailpipe. It has a rolled edge and is chrome (or at least looks like chrome). Inside of this you can see the rough edge of the tailpipe, which I believe is stainless steel(?). This may have a bronze tone, similar to the color of the resonator just upstream of it.
Or are you refering to the inner surface of the exhaust tip - where it comes in contact with the tailpipe? The chrome plating here may have discolored due to heat and/or exhaust residue.
Old Mar 29, 2005 | 11:50 PM
tiggerfink's Avatar
SL500 and A-CLASS
Ah! This appears to be the German way to chrome. Chrome over brass. I knew they did this for vintage Mercedes but not the new ones. Cannot remember the name of the technique.
Maybe I am wrong, but I hope I am right.
Lets say if you take the chrome exhust tips off, the inner side looks like brass. I can see a perfect line that forms a circle where the chrome meets the brass color on the edge of the chrome exhust tips.
Old Mar 30, 2005 | 12:07 AM
LovinMercedes's Avatar
2026 Mercedes CLE53A4 AMG Cabriolet and 2025 MAYBACH EQS680V4
I am going to look more closely. Never noticed this.
Old Mar 30, 2005 | 12:01 PM
RadSteve's Avatar
2002 BMW 745Li Black/beige, 2006 SL600 Capri Blue/Black still on order
Those chrome tips are OE on your car, right Lovin?
Old Mar 30, 2005 | 08:28 PM
blueSL's Avatar
SL55 AMG
Is it just a metal polish residue stuck between the inner and outer? Time to get the Q-tips out!
Old Apr 2, 2005 | 03:26 PM
tiggerfink's Avatar
SL500 and A-CLASS
Originally Posted by joeym7
Hi I believe the shell is anodized and then chromed,either way if you look you will see they are the same shape as the fog lights and also attribute to the special exhaust sound.joeym
The fog lights have the brass color to.
Old Apr 2, 2005 | 04:14 PM
Talking Time for some work Tiggerfink...
My pipes are OEM.
I got down and looked and surprisingly enough I do see the line around the whole pipe.
On my car one side of the line is the bright chromed metal and on the inner side it is just a duller colored metal but sorry Tiggerfink, not brass but silver.
I believe the line is just the point where the chroming ends. I believe your brass color is from the exhaust use so Blue is right, it is time to get out the Q-tips.
My guess is you will need some metal polish.
