SL/R230: Door Sill Translation
For those of your who have asked for the PDF, here's the text in English for those of you whose German is a little rusty...
Installing illuminated door sills
- Remove left and right rear cladding panels
- Remove left and right storage boxes
- Remove read wall cladding panel
- Remove rear centre console cladding
For removal of standard parts, look at WIS
Boxes...
Install the illuminated door sill wiring loom and fix to the car's cable loom
Wrap the converter in felt strip and fix it to existing wiring loom with cable ties
Protect the wiring loom in the centre of the car using a rubber tube and grommet
Install the cable loom on the other side of the car in the same way
If the TV tuner is installed, uninstall it temporarily.
Legend:
Connection to the door contact switch
Legend:
Power converter
Box:
Adjust the cable length and connect to Fuse No 60 (3A). One contact spring, part no A 0045450026 required
Box:
Find the connection to the door contact switch in the original wiring loom and connect to the door contaxt switch:
Pin 1 brown cable (Connection 31)
Pin 2 grey/red
2 contacts A 0135451626 required (each side)
Page 2 follows later...
Boxes...
Legend:
Legend:
Power converter
Box:
Box:
Pin 2 grey/red
