SL/R230: TV in the SL's
Since the TV in COMAND obviously works in PAL for the UK, and I know it works with SECAM in France, does it mean the system is fully multi-functional for all countries? Is it digital in any way, collecting Free-to-air broadcasts, or only an analogue system?
Would the TV in a UK spec car work in the USA? Would it work in NZ which uses PAL but has different sound spectrum?
Not available in the US, so doesn't work with NTSC; does work with PAL and SECAM; doesn't receive anything digital/freeview, analogue only; if the sound sub carrier in NZ is different, you'll see the picture but no sound; most would say it's a waste of money.
What is a total waste of money is not so much the TV but the stupidly low speed at which the picture goes. You can't watch the news, as I tried last night, and still crawl along in a queue..
Neither could I turn off the sat nav voice and just have the map. So every few minutes even the news would mute while the woman instructed me where to crawl! There must be a way out of that - I'm getting to be a true technophobe.
I've otherwise enjoyed watching Grand Prix's on TV while the wife shops - a few other occasions have justified the TV's cost, I guess...
..........you can mute the volume of the navigation lady by turning vol knob down when she speaks. That will decrease or elimate her voice while not affecting the volume on the TV for that session. Alternatively, you can change the volume of the nagigation chickrelative to the stereo volume by going into the audio menu of your Comand.
Ted
Ted
From now on its going to be known as "nagigation" !
If you have an older R230 SL with D2B based audio system - the comand will accept a TV tuner no matter wether it is eurospec or US spec...it is just a matter of programming through stardiagnose.
If you have a newer comand with MOST based audio system, you will need a eurospec comand in order to be able to use the mercedes TV tuner but that will make it impossible to use the MB satelite radio system.
The older D2B based comand can be connected to an aftermarket video adapter to feed in a video source without using a mercedes TV tuner...these adapters are fairly cheap.
A similar adapter is available for the MOST based comands as well but this adapter is way overpriced.
All comands (D2B based and eurospec MOST based) can be programmed to have DVD and or TV enabled in motion...it is just a matter of having the right tool to do so.
Mercedes has a digital TV tuner that can be connected to the original mercedes analogue TV tuner and it will use one of the 2 AV inputs to display the digital TV...the digital TV tuner will share the antennas with the analogue TV tuner and is controlled by a remote control (cannot be controlled from the headunit).
greetingz,
Just a thought.
