SL/R230: StephenK and RadSteve, the answer to your prayers...
IMHO, this is the best option for both your cars. Will look absolutely gorgeous, especially if you get them in the SL65 color which is hyperblack. You can also get them in the regular silver color. They are 19" inch wheels so you would have to replace your tires which you should do anyway as the Michelin Pilot sports are much better.
Happy hunting...
Happy hunting...
Wonder why?
Wonder why?
MB uses a few brands of tires, as of late the most commom seems to be Michelin, Pirelli, and Conti's with the Michelin's being the most expensive. The guy's on the E55 section don't have the kindest words for the new Conti Sport 2's but they all seem to love the new Pilot PS2's.
Amazes me the cars were built so close together yet they have different tires. I know Mercedes uses all three depending on which is the best deal at the time but just surprised they could be so close and yet have different tires.
Something in my head is telling me that they only rotate between the Michelin's and the Pirelli's on the SL600's but when it comes to the SL500's that the Conti's are part of the rotation.
I remember when my SL600 was coming in I had the dealer order a set of Michelin Pilot Sports just in case the Pirelli's came with the care. I wouldn't have taken the car with the Pirelli's. That is when I believe they told me I had a one in two chance, not a one in three like on the SL500's.
I haven't had the opportunity to try the new Pilot Sports. On a previous BMW, I had the Pilots and they were quite hard and noisy, but I'm sure they've improved a lot since 1994.
Jeff
Jeff
It is my understanding that Bridgestones are great for reducing road noise.
Once the tires heat up a little they're at 34/35 psi according to the TPM. I would like to put Nitrogen in, then I think i could start with a higher base pressure. Nitrogen expands less so there is less pressure swing between hot and cold.
Jeff
Jeff
Jeff
Same single piece look which can only be accomplished by being hand made.
J
She remarked that I had the Michelin's on my car - which was good. She then told us - per what other's have said here too - that MB has several tires they put on the car from the factory. What you get is based upon what is in supply at the time of your build and not relevant to what is listed in the brochure for the car.
Ideal gas law: P*V=n*R*T, Where P=pressure, V=volume, n=number of moles present, R=universal gas constant, and T=temperature.
For a given amount of any gas, n and R are constants, so put them both on one side of the equation and you have: P*V/T=n*R.
So, for the same amount of any gas at two different temps, volumes and pressures: P1*V1/T1=P2*V2/T2.
Jim
Jim
Nitrogen is a dry, inert, non-flammable, enviromentally friendly gas used for years to inflate airplane tires, off-road truck tires, military vehicle tires, and race car tires for improved performance. Compressed nitrogen contains less moisture than compressed air. When the tire heats up, moisture in the tire vaporizes and expands, causing the pressure inside the tire to increase. Even small changes in tire pressure can noticeably affect the handling of the car. By using nitrogen instead of air, race car teams have more control over how much the pressure will increase when the tires heat up.
Nitrogen Tire Filling Benefits...
Nitrogen permeates through the tire 3 to 4 times slower than oxygen - tires maintain pressure longer for better fuel economy, better tire life, and increased safety.
Nitrogen reduces oxidation to tire rubber and rims caused by oxygen in standard compressed air.
Nitrogen filled tires run about 20% cooler than tires filled with standard compressed air - tires last longer.
http://www.talontire.com/nitrogen.html
BTW, a lot of the sites that I visited make the point that [big] airplanes use nitrogen in their tires. I suspect that the reason that they do so not only worries about oxidation, but also that anybody involved with aviation doesn’t want anything that supports combustion better than air (and compressed air supports combustion better than uncompressed air) tucked up in the wheel wells of their planes.
There is a lot of money to be made in selling equipment to fill tires with nitrogen. There is money to be made in charging consumers for filling their tires with nitrogen. Therefore, there is a lot of money to be made in convincing people that nitrogen is a good thing. The N2 hype machine is operating effectively. There look to be some advantages: lower oxidation, perhaps lower leakage. But, in spite of web sites that say things like “nitrogen doesn’t expand or contract with temperature” (http://www.woodalls.com/cforum/index.../14872995.cfm), with respect to obeying the ideal gas law when used to inflate tires, nitrogen and oxygen are essentially identical.
It’s a fascinating story of science meeting marketing. Marketing is winning.
Jim
Always telling me to Visit workshop.
I HATE THE WORKSHOP, DON'T YOU UNDERSTAND?!!
