SL/R230: How well does the rear wind deflector work?
Old Feb 20, 2013 | 09:34 PM
Sgooter's Avatar
'14 E350, '03 H-D FXDL
Originally Posted by mitviet
at $700+ new from MB dealers, windscreen is indeed a commodity when you sell your MB w/out it and then sell it later on eBay. I installed on my '06 SL500 this week and it looks good.. haven't tried it yet due to weather. I can say this though, I don't plan to raise the roll bar up as indeed, the double screen would make it very hard to see.
Btw, anybody knows if the roll bar would be automatically raised up if the top is down and you are in a spin or about to be in an accident? you know just like how the door will be unlocked/ windows lowered down, etc.. when MB cars sense that you are losing control of your vehicles.
"The roll bar raises automatically [and very fast] in an accident or in a critical driving situation." Per the owners manual.
Old Mar 2, 2017 | 11:15 AM
Kareem Khalil's Avatar
2007 SL600
Anyone selling a wind deflector for 07 SL600?
Old Mar 2, 2017 | 04:11 PM
stykshooter's Avatar
SL 600
I have one for 04 sl600 that I don't use but no bag
Old Mar 2, 2017 | 04:13 PM
2007 SL600
Will that fit my 07? No bag is not a problem as long as the actual deflector is in good condition and fits my car.
Whats the best way to contact you stykshooter?
Old Mar 2, 2017 | 04:16 PM
SL 600
When I get home tonight I'll look for a part # to verify
Old Jun 25, 2017 | 08:06 AM
Tommyboy928's Avatar
89 SL500 Silver ,97 SL500 Carlsson 04 Mercedes SL55 AMG , 07 Mercedes SL55 AMG convertedBlack series
Sucked ashtray clean
I just got a used windscreen and will put on my 'new' '06 model... don't know how yet but the instruction from the Owner's manual doesn't look too bad.. Thanks for the tip on damaging the roll bar.. I will put some type of felt cushion under the buckle belts. But quick question: when the top is down, i noticed the 2 little rear windows are also down as well. I don't seem to find a button/control to raise these 2 rear windows... am I missing something here?
​​​​​. IT's same buttons as front windows, just press one more time,when front window is all way up or down.. tested the system in 250 kmh hour, with windshot down , the vacuum sucked all trash out off the Ashtray ,pluss everything all light stuff,papers , windows up all ,screen up, just wind noise . Amazing difference..
Old Jun 25, 2017 | 08:09 AM
  #32
Fits all models
it fit all models , 07 has many updates, but not for the windshot
Old May 11, 2018 | 11:35 AM
  #33
BigOldBlue's Avatar
Veteran: Marine Corps
2006 SLK350/2009 SL550/2015 SL400/2015 S550e
Post Have one for sale?
Does anyone have a black one that is like new, for my 2009 SL 550 that they would like to sell? Thank you! Bill
Old May 11, 2018 | 03:37 PM
  #34
Aussiesuede's Avatar
SL500
Originally Posted by vraa
I keep the rollbar up when the top is down.
With that, the screen is on.
The GF used to think the only way to use the windscreen was with the rollbar up. One day she complained about the blindspot created by the raised rollbar when trying to make lane changes to the left on the highway. I laughed and said that's why I never raise the rollbar, but rather just raise the windscreen. It was then that she realised the windscreen wasn't part of the rollbar and that it could be raised independent of the roll bar. She also hadn't realised that the windscreen had 2 parts. one vertical screen, but also an attached horizontal screen. Since the horizontal portion is attached to the rollbar, it can't be used when the rollbar is raised. Now she drives exclusively with the rollbar lowered and the windscreen deployed, with all 4 windows raised and is happy as pie with the almost zero wind turbulence in the cabin.
Old May 12, 2018 | 11:31 AM
  #35
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I don't use the windscreen as I find it does very little to reduce wind turbulence in the cockpit. On my W209 CLK, with the windows and the windscreen raised, I could do 120mph on the freeway and have just a gently bit of air movement, like a sunroof on a car. On the SL, raising the windows helps with turbulence, but it seems that raising the windscreen actually increased wind in the cockpit, especially lower, around the console and footwells.
Old May 13, 2018 | 06:00 PM
  #36
m5zealot's Avatar
Top Answer: 1
1988 BMW M5, 1989 BMW M3, 1979 Mercedes 450 SEL 6.9, 2006 SL55 AMG w/ P30 Performance Pack
Talking
Originally Posted by ToonArmy
I use the windscreen with the rollbar down when traveling on freeways. I perceive a very noticeable calming - watch your passenger's hair to see the difference. My girlfriend always requests the screen up.
Not to say that it isn't a matter of personal preference, but I do believe it does make a difference. Just my opinion.
It makes a huge difference! My ears are very sensitive to wind buffeting....drives me crazy! The wind blocker on my 2006 SL55 works two ways and not sure if most know the difference. You can have it "up" with the roll bar down. It works best in this configuration. The top portion that rocks forward almost touching the headrest blocks turbulent air blowing backwards right into your head. The bottom (flat) section blocks the same air turbulence from blowing down into the rear compartment and forward between the seats. If you put the roll bar up, the blocker folds into a one piece unit blocking a lot of rear visibility. It also allows turbulent air now to flow down the rear compartment forward thru the seats. It also allows the screen material to flap around looking like it's broken. This configuration is useless unless you don't want the driver behind you to not see you. (it's like a solid curtain now but practically useless)
If you really think the windblocker doesn't help, drive your car at 65 mph in the middle of winter with windows down and no heat! Trust me, you will feel the difference! As stated rolling up all 4 windows really keeps the cabin vitually free from air turbulence, but to me, it's silly to have the top down and windows up! That defeats the purpose of the convertible experience IMO. I have owned several convertibles for many years and every wind blocker device has made a big difference to me. Just my 2 cents.
Old May 16, 2018 | 09:30 PM
  #37
kbdixon's Avatar
Personal observations I have had a R129-1994 and an R230-2008 they both came with windscreens as OE, at highway speeds with the windows up they make driving and talking acceptable. In the 230 screen up and all 4-windows I can talk on the phone thru Bluetooth with no problems. The screens are easy to find Ebay/amazon I have never used the bag to store them, they don’t damage the roll bar in either car. I find the shelf they create,top up, is useful for storage.
Old May 17, 2018 | 11:52 AM
  #38
TheSaint's Avatar
350 SL, R230 - 300 SL, R129 - 1964 Corvette Sting Ray Sport Coupe - Porsche 911 Twin Turbo (sold)
I been thinking of buying a wind deflector (windschott) but if i do i want to get the wind deflector in the same color as the interior of the car
Any here knows who sells wind deflector in a light beige color as shown on the picture here
Old May 17, 2018 | 01:23 PM
  #39
BigOldBlue's Avatar
There is currently one for sale, I just saw it as I was searching for black. Do a thorough search and you should find it.
Old May 17, 2018 | 04:51 PM
  #40
BigOldBlue's Avatar
Here are (2) in light beige:
https://www.ebay.co.uk/p/Beige-Windb...d=392005172380
https://www.ebay.co.uk/itm/252741178454?clk_rvr_id=1534441488222&rmvSB=true#s hpCntId
Old May 17, 2018 | 10:03 PM
  #41
danaw007's Avatar
2011 SL550
In my SL550 the windscreen cuts the turbulence by 60-75%, huge difference. If it doesn't cut it significantly on your SL I would look at other owners SL's or take a test drive in one that is the same MY as yours to note the difference and how it's installed as well. Just my two cents.
Old May 25, 2018 | 04:05 PM
  #42
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
I'm sure danaw007 is right about that. On our 2005 model the difference is decisive for comfort. Sometimes I wonder why it is so restless in the car - ah forgot to put the screen up - *flip* and all is well.
Old May 28, 2018 | 08:41 PM
  #43
JaySee56's Avatar
2004 sl55, 2011 CTS coupe
The wind screen extends the "top down" season by 2-3 weeks in the spring and the fall. The heater blowing generates a bubble of warm air in the cockpit that is quite enjoyable. My roll bar is never raised and the screen is never removed, so the slight dents the screen's straps make in the roll bar cannot be noticed.
Old May 31, 2018 | 10:33 PM
  #44
danaw007's Avatar
2011 SL550
If you want your lady to go with you in the roadster you need to learn how the windscreen functions and utilize it, like JaySee56, my roll bar is never raised and screen is never removed. I can take my wife out with the top down and she won't complain about her hair at all.
