SL/R230: Sirius Satellite Installation
Here's my question: What needs to be done for installation, specifically what needs to be taken apart? And does the COMAND unit need to be pulled from the dash?
I plan to use the under the hood sat antenna like Lovin had in his SL600.
The comand has to be coded for the changes and to make the sat button actually work.
Then you would need to pull the sill plate etc. to route the antenna wire under the hood. You can also mount a mini antenna in the interior right in the middle of the dash at the base of the windshield.
The list price you quoted is for the parts *only*. I called several places, all were about that same price. The dealer charges around 400 or so for labor, thus totalling about 1100.
I want the dealer to do the install because I want the warranty to remain intact. If an independent shop does the install, MB can void the warranty.
