SL/R230: Roll Bar Picture
Old Nov 11, 2005 | 07:30 PM
StephenK's Avatar
2006 SL600, 2001 S500, 1996 SL320
Roll Bar Picture
Does anyone have a picture of the roll bar being up on their car they could post or email to me?
Old Nov 11, 2005 | 08:16 PM
vraa's Avatar
Here ya go, and some with the screen only.
Attached Thumbnails Roll Bar Picture-dsc04793.jpg   Roll Bar Picture-dsc04794.jpg   Roll Bar Picture-dsc04795.jpg   Roll Bar Picture-dsc04796.jpg   Roll Bar Picture-dsc04797.jpg
vraa's Avatar
Last.
Old Nov 11, 2005 | 08:21 PM
StephenK's Avatar
Thanks Ricky!
Old Nov 11, 2005 | 08:41 PM
vraa's Avatar
Anytime, what for though?
Old Nov 11, 2005 | 08:48 PM
StephenK's Avatar
What for
I am going to a track that has mentioned all kinds of NHRA rules and one talks about the roll bar and convertibles. Don't know if they will allow me to run or not.
Old Nov 11, 2005 | 08:50 PM
vraa's Avatar
Good luck.
Hopefully they'll let you, I can only suspect that the extra weight over the rear wheels is a good thing for traction.
Old Nov 11, 2005 | 08:53 PM
StephenK's Avatar
No No No
Originally Posted by ricky.agrawal
Good luck.
They may not let me run period. Top up or down. I am curious what others have run into with this.
A roll bar will be mandatory in any full-bodied car running 11.00-11.49, or convertibles running 11.00-13.49 or dune buggy type vehicles running 12.00 &slower. Permitted in all cars. All cars must have neutral safety switch and reverse lockout. 3" Driver restraint system meeting SFI spec 16.1 mandatory if roll bar or roll cage is required.
Does or SL meet these requirements?
3" driver restraint????
Old Nov 11, 2005 | 08:57 PM
vraa's Avatar
You are too fast
I think the 3" driver restraint is the width of the belt?
Old Nov 11, 2005 | 10:24 PM
tiggerfink's Avatar
SL500 and A-CLASS
The SL meets the requirements here.
Old Nov 12, 2005 | 09:21 AM
Scruffyone's Avatar
SL55, ML500, GT3 RS, 997C2S
They won't know what your times are until after the first run.
Old Nov 12, 2005 | 10:59 AM
Overclocked412's Avatar
2003 Black SL500
Just dont put down the top, I honestly dont think they will know its a convertible. If they do, act dumb :p.
Old Nov 12, 2005 | 06:15 PM
vraa's Avatar
Putting the top down transfers some weight to the rear which may help traction wise.
Old Nov 12, 2005 | 06:36 PM
lorinserbenz's Avatar
none
I think the 3" restraint is refering to a "3 Point" seat belt.
Old Nov 12, 2005 | 09:57 PM
NOTKTS's Avatar
g
A guy with an SL65 had the same problem here at Bithlo. They said that he had to have a roll cage to run in the 11's. He tried to argue the point about the roll bar... they asked him to leave. I think it was in Automoblie Mag a while back
It could depend from track to track depending on how lenient they are on their policies.
And with the top down isn't the drag coefficient increased by a fair amount?
Old Nov 12, 2005 | 10:01 PM
vraa's Avatar
I wouldn't think so. Isn't drag coefficent how much frontal area you have? I think putting the top up, or down wouldn't change that.
I guess though, there would be more air turbulence from the air not flowing smoothly over the car. I honestly have no idea.
Old Nov 13, 2005 | 03:07 AM
tiggerfink's Avatar
SL500 and A-CLASS
Did StephenK make it to the track?
Old Nov 13, 2005 | 02:05 PM
CASL55's Avatar
2004 SL55, 2005 E500 Wagon
Drag coefficient is drag normalized to (divided by) the drag for a standard idealized shape of the same frontal area that brings all impinging air to a halt. The shape is a bit slipperier than a flat plate.
Cd = D/Ds
The drag coefficient is a measure of how slippery a car is compared to other cars of the same frontal area. Putting down the top doesn't change the frontal area, but it does change (increase) the drag and the drag coefficient.
Jim
Old Nov 13, 2005 | 05:18 PM
vraa's Avatar
Cd = D/Ds
Jim
Thanks Jim, do you think it'll have a very severe effect on the 1/4 times, maybe enough to offset the advantage of extra weight (therfore traction) during launch?
Old Nov 13, 2005 | 06:49 PM
CASL55's Avatar
Do you think it'll have a very severe effect on the 1/4 times, maybe enough to offset the advantage of extra weight (therfore traction) during launch?
I don't have enough data to do the calculation. I'd have to know the effective weight on the rear wheels with the top up and down, and the drag coefficient with the top up and down to even start. I say the effective weight because there are two effects generating downward force on the rear wheels: 1) the weight and front-to-back center of mass that dictates which wheels take that weight, the dynamic transfer of force from the front wheels to the back wheels under acceleration, which is detirmined by the amount of acceleration, the mass of the vehicle, and the height of the center of mass. Then I'd have to know how much of the run is traction limited. I think it's too complicated.
That said, let me hazard an educated guess. I'm surmising that the part (in time, let alone distance) of the 1/4 that's limited by traction is much less than than the part that isn't. I also surmise that the dynamic transfer of weight to the rear of the car will be lower with the top down, since lowering the top will lower the center of mass of the vehicle. So the gain in static rear wheel weight will be at least partially offset by a loss in dynamic rear wheel force. But there will be more drag thoughout the run. I'd guess lowering the top wouldn't help 1/4 times. But I could easily be wrong.
One thing that will help is putting the driver's and passenger's seats all the way back, if the driver's feet can still reach the pedals.
Jim
Old Nov 14, 2005 | 11:06 AM
craiglieberman's Avatar
2005 SL600 Designo, Graphite Gray, Panorama Roof
Actually, they are referring a three inch wide seat belt, aka a racing harness.
Readily available from Sparco, but it usually requires drilling to mount the anchor points, or at the very least, removal of the factory seat belts to use those mounting points (not practical in many cars).
And no, our roll bars do not constitute NHRA-legal roll bars. There's not enough "points," which simply described is the number of bars making contact with the car's chassis/floor.
We need something like this:
http://rds.yahoo.com/S=96062883/K=4+...ampics/33b.jpg
It's possible to make one, but it'd take alot of interior dissassembly and surgery to get it in, plus, the factory roll bar would need to be disabled or removed and overall, it's ugly.
My advice? Wait till all yoru mods are done, run as many passes as they let you till you're kicked off...then find another track.
