SL/R230: Damage to RIMS
Old Jul 9, 2006 | 10:15 PM
StephenK's Avatar
2006 SL600, 2001 S500, 1996 SL320
Damage to RIMS
I had the dealer rebalance my tires, one rim looks like this. The black tapelike substance will come off, but the damage along side of it is into the finish. Should this be expected when removing the weights?
Old Jul 10, 2006 | 07:19 AM
meegle's Avatar
2007 SL550, 2008 S65, Golf cart and a few non-MB vehicles
Unfortunately, that will happen as the adhesion from the wheel weight does tend to damage the clear coat on wheels. Hopefully most of it is hidden from the outer side.
Old Jul 10, 2006 | 07:25 AM
vraa's Avatar
I don't think that's from removing the weights, I think that's improper handling of the wheels.
StephenK and I talked about this in MSN.
Old Jul 10, 2006 | 09:45 AM
prsmith777's Avatar
06 Infiniti FX35, 07 SL55
Dont you love the dealers?
This is what my dealer did to my rim:
Old Jul 10, 2006 | 09:48 AM
meegle's Avatar
Ouch! looks like they tried using a screwdriver trying to pry your tire back on.
I too, have very little confidence in dealers.
Old Jul 10, 2006 | 09:54 AM
Itzkirb's Avatar
Check my Sig
Ouch! That sucks!
Old Jul 10, 2006 | 10:04 AM
vraa's Avatar
You'd think they'd have all the right tools and the know how seeing how they WORK WITH CARS 24/7!
Old Jul 10, 2006 | 12:18 PM
LovinMercedes's Avatar
2026 Mercedes CLE53A4 AMG Cabriolet and 2025 MAYBACH EQS680V4
I hope they bought you a new wheel!
Old Jul 10, 2006 | 12:26 PM
JDM's Avatar
JDM
2011 C300
I had schwab put new tires on mine and when they spun that cone shaped hold down onto the center cap hole, it left a ring shaped scrape all the way around the center. Now it shows even w/ the caps in place. The next time I got tires I had to point it out to use the nylon hold down instead of the steel one. I recently took my truck in for a rotate and they dinged the centercaps w/ a screwdriver prying them off. Dangit! Now I remove my own center caps off the truck, and babysit the benz. Too fast, too careless, and I get to drive the mistake home.
