SL/R230: Compass
Old Oct 19, 2006 | 07:16 AM
mikefili's Avatar
Compass
I have not been able to find a screen that has a compass, it seems that the only way I can determine direction is by having the nav set to North up, and then seeing what direction the arrow is pointed, there must be a compass function, I thought it would be with the outside temp. reading, but no luck.
Every $10,000 car has a compass function, so I must be missing something.
Old Oct 19, 2006 | 08:03 AM
Energy34108's Avatar
05 SL 600 Renntech
I dont know if there is an actual compass, but if you use the menu button on the steering and scroll till you see heading instead of your mileage, you should see N,S,E, or W under the RPM.
If that does'nt work you could alway's get a bunch of $10,000.00 cars with what yours cost.
Old Oct 19, 2006 | 06:50 PM
AMG 17GT's Avatar
R Nine T
Gas is on the right.................Stab it and steer
Old Oct 19, 2006 | 09:28 PM
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
And enjoy the ride!!!!!!!! wohooo
Old Oct 20, 2006 | 06:34 AM
detailas's Avatar
2003 SL500, 2001 Jeep Grand Cherokee Limited
It does not seem to work in my 2003. Pretty sure I checked all the sub-menus..
The only 'S' or 'W' I see under the RPM is depending on the Sport / Winter setting (S/W switch)..
George
Old Oct 20, 2006 | 07:44 AM
mikefili's Avatar
I find the same thing as "DETAILAS" does on his car, I wonder if it is a function that has to be programed in.
Old Oct 20, 2006 | 08:29 AM
detailas's Avatar
Energy34108's car is a 2005 model. Maybe there has been a change in the menus, etc in post 2003 cars..
George
Old Oct 20, 2006 | 10:58 AM
05 SL 600 Renntech
http://www4.mercedes-benz.com/e/cars...edienen06.html
Basically if you have your nav off you will not find anything, but if you have your nav on and do not choose a route it will only show direction of travel like N, S, W, E.
I hope this helps and if you still dont find it just buy one of those round ones and stick it on the dash.
Old Oct 21, 2006 | 03:48 AM
detailas's Avatar
LOL!!!
Old Oct 21, 2006 | 06:17 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
1) Its 8:00 am and the sun is almost in my face while going to work.
2) Its 5:00 pm and the sun is almost in my face while going home.
Which direction am I travelling in both instances?
Old Oct 21, 2006 | 07:07 AM
benzmodz's Avatar
W203 slightly modified
In a space ship flying into the sun ?
Every girl knows the answer ..... EEEEEWWWWW
Old Oct 21, 2006 | 10:40 AM
detailas's Avatar
Originally Posted by benzmodz
..... EEEEEWWWWW
Unless you are sitting in the trunk facing backwards, in which case it's WWW-EEEE..
George
