SL/R230: fuel sloshing sounds over speed bumps
07 SL550; C32 (sold)
whenever i go over a speedbump, i hear sloshing sounds from the fuel tank. i had thought mb fixed this issue. is this suppose to be normal when going over speed bumps?
2006 SL600, 2001 S500, 1996 SL320
Sounds Like
Sounds like the same issue I am having. Dealer is going to replace the gas tank, saying the inside of the tank is broken. When you back up slightly and brake do you hear it then too?
i'll check to see if i also hear it too when backing up and hitting the brakes. it might not be as noticeable but over bumps it's definitely sloshing like the ocean.
edit: yup, sloshing sounds backing up and hitting the brakes.
2003 SL500, 2001 Jeep Grand Cherokee Limited
amgme - check out this recent thread
https://mbworld.org/forums/sl-class-r230/168000-sound-gas-tank.html
George
George
