SL/R230: New Kleemann kompressor
Old Mar 26, 2007 | 10:46 PM
Acez's Avatar
2001 Kleemann CLK 230K, 2006 CLS 350, GTR R35
good news to SL 550 owners
KLEEMANN introduces a new Kompressor system developed for the M273 V8 engine range fitted in the current 500/550 model ranges.
Like the Kompressor system for the outgoing V8 engine range (M113) the new design integrates the inlet manifold, intercooler and Kompressor in one integral unit. A compact design that ensures factory-like fit looks and quality.
KLEEMANN introduces the EMS (KLEEMANN Engine Management System)
Cutting edge engine management technology – Sporty engine characteristics
The anti-clockwise rotating Roots type Kompressor is characterized by its unique ability to develop plenty of power at low boost pressure and this type of supercharger has proved its reliability and efficiency for many years. The new electronically controlled fuel injection and management system KLEEMANN EMS is on the other hand a technological break through.
The fuel injection and management system allows boost pressure to vary from 0,3 bar to 0,70 bar as the engine rotates up the rev scale. The varying boost pressure ensures progressive and sporty engine characteristics known from naturally aspirated high performance engines. Increase in rpm results increase in increased power output all the way to up to the rev limiter. Furthermore the system ensures an effect curve without any bumps or valleys.
The EMS reduces boost pressure thus power output a fraction of a second before gearshifts to ensure smooth and gentle shifts.
Punch from idle - Flat torque curve remains intact
Like the earlier generations of KLEEMANN Kompressor solutions the new system still ensures plenty of torque from low revs thus a car fitted with the new system will have plenty of punch from rev levels just above idle. 90% of torque is present at 2000 rpm.
Safe, durable, reliable
The low boost pressure of just 0,30 – 0,70 bar makes the system safe and provides long-term durability for the engine. To further improve the safety aspect the EMS features a safety mode constantly monitoring the fuel - boost pressure ratio ensuring that the engine cannot run lean thus suffer damage to the engine. In other words the boost pressure and amount of fuel injected to the engine will always comply.
Even if the car is driven in an area of high altitude (less oxygen, low pressure) and down to sea level boost pressure and fuel supply adjusts automatically to protect the engine from running lean.
Technical specifications
Kompressor:
Type: Roots type
Boost pressure: 0,30-0,70 bar @ max 12.000 rpm, electronically controlled bypass.
Capacity: 2,0 ltr (122 cubic inches) pr. Rev.
Intercooler: 1 internal and 1 external aluminium air to water intercooler.
Output (500/550 engine)
Effect: 475 Hp
Torque: 625 Nm
Output (500/550 engine) with KLEEMANN Headers and Exhaust:
Effect: 505 Hp
Torque: 660 Nm
Old Mar 27, 2007 | 03:26 AM
amgme's Avatar
07 SL550; C32 (sold)
wonder how much this is gonna cost? i bet the cost of this + new sl550 is gonna be close to a slightly used sl55.
any mention on any performance numbers? 1/4 mile or 0-60 times?
Old Mar 27, 2007 | 04:00 AM
Acez's Avatar
Wink
kleemann guys can answer those questions. i'm just informing the guys here
