SL/R230: Removing Grille
Old Jun 22, 2007 | 01:31 AM
MikeSL5's Avatar
07' SL550
Removing Grille
Anyone know how to remove the grille. I took out the 4 bolts on top but the bottom part wont come out.
Old Jun 22, 2007 | 01:40 AM
glennbaz's Avatar
2003 SL500
If I remember corretly after removing the top screws, pull top away from radiator support area then lift up releasing lower tabs from indents.
Glenn
Old Jun 22, 2007 | 02:14 AM
johnny5's Avatar
Its pretty easy actually........
First take off the 4 Screws (Which you have done)
Pick one side first Right or Left Side and push in towards the radiator gently (if you put to much force you may break the grills or ram it into the radiator or something) and you'll hear a pop which is poping off the clip (You'll understand what I mean when you actually get it off and look at the weird design. Once that is off proceed to the next end and follow the same steps and its out! Hope this helps.
Ive taken mine off a few times working on a project which I will post in a day or two why I took the grill off!!
Old Jun 23, 2007 | 03:52 AM
MikeSL5's Avatar
07' SL550
Thanks, will try it tomorrow and see if it'll come out.
Old Jun 23, 2007 | 04:38 AM
johnny5's Avatar
Let me know if you have any problems and Ill be more than happy to help you further. Good Luck
