SL/R230: How to remove center wheel cap?
Old Sep 27, 2007 | 07:27 PM
Dr. FOB's Avatar
SL500
hey guys...
What is the best way to remove center wheel cap from the outside with out taking off the wheel?
Old Sep 28, 2007 | 04:59 AM
R230_Nicke's Avatar
SL 600 640bhp/1000Nm
I dont think You can.
Not without damaging Your wheel.
Old Sep 29, 2007 | 04:47 PM
oofreakoo's Avatar
2003 SL500, Lamborghini Gallardo
Not sure what wheels you have but try removing the wheel first and look from the inside out. Maybe you can press it out or use a long screw driver for the clip (if it has one).
Old Sep 29, 2007 | 07:54 PM
gocargo's Avatar
Steel Grey 2012 ML350 is wife's
I simply drilled a hole (most caps are plastic) inserted a screwdriver into new hole and then popped them out. It's a piece of pie to install new caps. Absolutely no wheel damage and replacement caps are inexpensive.
Old Sep 29, 2007 | 08:03 PM
WordSmith's Avatar
SL550, ML350, 66 Corvette
I also drilled mine, popped them out with a screrwdriver, and replaced with new ones. Easy operation.
