SL/R230: WIDE rims, fitment? 19x9.5" and 19x10"
Old Dec 12, 2007 | 11:39 PM
ClayMan's Avatar
Front: 19x9.5" ET35
Rear: 19x10" ET25
Will these clear the brakes? Will they be sticking out beyond the fenders?
Old Dec 13, 2007 | 03:08 AM
CY's Avatar
CY
SL/M6
Usually with this car the rims are either an exact fit built for the SL type offset or need spacers....Ive had 3 different rim types on my SL. The 1st was staggered 20's which needed spacers...the second was staggered 20's that were almost the crrect offset but a feww mm off so they could fit other appliations besdes the SL/CLS and the third were Lowenhart 20's (the rear is 11 inches and has a 4 inch lip) which fit like a glove and permform much better then the other two options.
Old Dec 13, 2007 | 08:16 PM
jrtireman's Avatar
2003 SL500
Originally Posted by ClayMan
Front: 19x9.5" ET35
Rear: 19x10" ET25
I think the front will fit but the rear should be closer to a +32 or +35 offset.
May want to check more on that. You could possibly use spacers but I wouldn't if I could avoid it. Hope this helps.
