SL/R230: Rim/Tire sizes
I'm looking for news rims this spring.
I was reading all forum to find out which sizes to use, but unfortunatelly, there are so many threads about it, that finallly I was lost.
So, I decided to make a topic about it if you are fine with it, so we can share information about our tire sizes and possible things...
Specially, I'm looking for someting that doesn't need spacers, I guess you too
Till now, I got such information/options of tires and rims sizes that i gathered from this forum:
18":
1) (F) 255/40/18, 8,5 (R) 285/35/18, 9,5
19"
20"
1) (F) 245/35/20, 8.5 (R) 325/25/20, 10
2) (F) 245/35/20, 8,5 (R) 285/30/20, 9.5
3) (F) 255/30/20, 8.5 perfect for lowerin'
Also, I find out that were a lot of threads which were not anwered at all.
Please, don't hesitate to put your known information about tire/rims sizes, so others coul find it fastly!
Maybe, we will come to final size which is the best for SL
i want to know what is the widest 20inch rim i can put on my sl without any problems?
Actually, if you read the list, the Carlsson 20x9.5s and 20x11s that are listed will require that you:
Bend in the rear wheelarch lips
Seal the wheel housing
Flare the wheelarches
This information is in the 'Notes' column on the list.
The reason why your "widest" question is not so straightforward is that the fitment is a result of the tire width and offset as it relates to the acceptable outside position and inner clearance. You'll need to either take measurements or get this data and might benefit from a wheel offset calculator: http://marksink.com/tire_wheel_offset/offset.html
So, for example: If you switch from standard 18x9.5 40mm to 20x11 35mm you'll lose 14mm of clearance and your outer edge will extend 24mm.
This could be leading to the conflicting reports on 20x11s that you've heard in that offset varies by wheel type and manufacturer.
and 20x10.5 with a 23 offset and 305/25r20 tire for the rear. I should be ok??
