SL/R230: Engine Undercover Piece Missing
I hit a road sign that had been lying flat in the roadway the other day. When I did it took a small chunk out of the black plastic material that is under the engine towards the front. Is this critical?
brian
brian
05 SL500
undercarriage covers
Some of the underneath panels are fiberglass and some plastic. The fiberglass panels can be repaired, the plastic ones replaced. They have no mechanicalbearing on the car from what I can see, other than to protect the underneath components from scraping on speed bumps, etc. Surprisingly, some of the front plastic pieces are inexpensive. I replaced a damaged front inner fender piece (there are two per side in the front, a front and rear for about $50.00. I would not get stressed over scrapes and cuts on the fiberglass pieces.
Brian
