SL/R230: My hardtop goes up & down "sluggishly"!
I'm afraid it's going to get stuck halfway up or down in operation.
My '03 SL 500 just turned 10,000 miles.
Stan
If you go to the dealer I'm very curious to know what they tell you. I think they may tell you that you need new hydraulics. If that happens the bill will probably be expensive, but a much cheaper alternative would be to do the repairs yourself.
I hope you'll post back with updates of your progress.
Where exactly is this hydraulic pump?
Stan
My Sl500 is an 03, but I bought it with only 7800 miles on it. It sat for a while in the former owner's garage. The top worked perfectly when I got it, but I believe that by operating it when I got it, that after so many years not being used, the fluid was quickly used somehow. This is my theory. It's not based on any real knowledge, but I'm trying to figure out why the fluid was so low. The hydraulic cylinder in the trunk is transparent...so you can easily see the level of the fluid. Mine was WAY below where it should be. Perhaps dry seals or something. I'm looking forward to Thursday night when I pick the car up. Hopefully, my slow top problem will have been solved.
Stan
All I know is...it's getting warm in in Pennsylvania, and I WANT my SL 500 totally operational.
Stan
Stan
I'm not sure how it's refilled or even where. That's why it's going to the dealer on Thursday. I'm sure hoping that's the real problem.
Stan
The Dealer fixed my top. That's the good news. It supposedly works perfectly after they filled the hydraulic container in the trunk and bled the air out of the system. I have a loaner car, and I will pick up the SL500 tomorrow morning.
The bad news is that they do not know WHERE the hydraulic fluid has gone to. Because it's an oil, it certainly didn't evaporate. My only explanation is that I bought this car last November with 7800 miles on it (an '03) and it did sit in a garage and not driven regularly. When I bought it...it must have been close to the point where the fluid was low and after some use, perhaps the seals were dry, and absorbed the fluid. I don't know. They checked all six of the hydraulic pumps and they were not leaking. They are stumped. But all I can do is take the car, enjoy it, and see if the fluid level goes down again. There are no spots on my garage floor, and they spent the entire day working on it. Because there were no parts involved, I will pay approximately $169.00 for labor. Had a part been replaced, my bill would have been $0 because I have an all inclusive warranty which covers the hydraulic pumps and everything.
Actually, I'm glad to pay the labor fee because this technician worked hard on it. I will also tip my service writer and mechanic at the Dealers as I always do.
I'll report again after I get the car and check it for myself. I WILL check the fluid level regularly to see if it happens again.
I'm up for suggestions.
Any Mercedes technicians out there? I'd love to hear your theories.
Stan
I will give it back to the dealer again, but they will be frustrated too when I call....since they worked with the car for a few days.
Hydraulic fluid is in a "closed" system. Any ideas out there?
Stan
Stan
Stan
How did this happen? Don't know. This car, though sat unused for quite a long time. I bought it with less than 8000 miles on it last year, and the previous owner had 10 cars in a thermostatically-controlled garage. I'll never know how it happened, but at least I will have a good summer without fear of the top freezing in half-opened position.
Thanks for all your suggestions and help.
Stan
Stan
What an "Adventure" this has been.
Stan
Thanks for all your input.
Stan
And just think ....... From what others have told me, it COULD have a LOT larger total than just $800.00 !
Glad all is good now wih yours. I have to have mine looked at for what I feel are the same symptoms when it goes in for Service B in a month or so. My nearest dealer is about 50 miles away.
Mike Lulejian
Lake Oconee, GA
If you suspect it's a hydraulic leak...it's easy enough to check. Take out the floor mat in the trunk, and then remove the large foam cover to the left. It's covering the hydraulic pump. You can see the level of the fluid on the side of this translucent cylinder. There are 2 marks near the top that are supposed to be where the fluid level is correct. You probably need to use a flashlight to shine on the side of the pump in order to see it sufficiently.
If your fluid is where it's supposed to be, then you probably do not have a hydraulic leak.
Correct me if I'm wrong, forum members. At least that's my understanding of the problem.
Stan
Stan
