SL/R230: SL500 sitting funny sometimes
SL55 AMG
I've noticed that sometimes the front left of my car sits lower then the front right, and the rear left sits lower then the rear right. It doesn't happen always and it varies as to what degree the difference is and which of the corners on the left side (wheter front or rear or both) is down, but it happens when the car's been sitting for a while ussually....I remmember seeing the rear left corner very low (hardly any wheel well gap, almost like the suspension collapsed on that corner) a couple of times when the car was on the driveway...which I don't think is completely level and it's on a slight incline as well.
This happens when the car has been sitting for a couple of days or maybe it's sitting on the driveway for a while...does this uneven lowering awkward stance occur due to non-level surfaces and how the car is parked on them? Is something wrong with the car? any input/advice? When I turn the car on and back out of the garage or driveway it will raise the front left corner back up or the rear left, or both depending on how low each was respectively an it does this quickly...the right side of the car seems to be fairly consistant when driven and when parked, even for a few days at a time...
thanks for the help
thanks for the help
SL55 AMG
someone must know what's going on here...yesterday I noticed the front left corner level was very low; when I turned the car onit gave me a bright Red warning..."Car too Low" on the left guage display ...then ABC something or another on the other guage display next to it.
what's happening with this?...what can be done about it? I was thinking about having the car lowered all around a little through STAR Diagnostic/dealer system or by using adjustable lowering links but how will that effect the issue I'm currently having?
Your car probably has a leaking control valve block in the ABC system. This can be due to a defect in the valve block or contamination in the hydraulic fluid. To correct the problem the ABC fluid should be flushed; and if this does not solve the problem, then the valve block needs to be replaced.
SL55 AMG
Update...just got it back from the dealer yesterday...they flushed the ABC fluid with fresh fluid and changed the filter, then did a diagnostic and performance test on all four corners on a shock machine (whole thing was $700 parts and labor...did I get repped off?? ) ...anyway my service writer told me to observe it for a while and if I got the warning again or had any more issues, then they'd replace the valve blocks (he said there's 2, one for in the front and one in the rear) to the tune of like $2,700
SL55 AMG
