SL/R230: delete esp!!!
Old Aug 17, 2008 | 08:55 PM
santomen's Avatar
delete esp!!!
I'm going to the dyno next week! does anyone know how to delete the esp so it won't come on when the car is on the dyno? I know the esp switch doesn't totally delete it! does anyone make a device that eliminates the esp??
Old Aug 18, 2008 | 01:40 AM
Saverino's Avatar
'07 S550 w/ AMG Package
You have to put the car in dyno mode.
Insert the key. Turn it so it stops on the first click.
Press the reset button 3 times.
On the menu that appears, scroll to a menu that says something like ESP Dynamometer Test, and switch it to on.
Old Aug 18, 2008 | 09:47 PM
metalica_23's Avatar
'06 SL600
A little more detail here:
https://mbworld.org/forums/w211-amg/209405-dyno-mode-07-08-amg-s.html
It's listed throughout the forum a bunch of times, if you search for "dyno mode". Worked wonderfully for me, looked it up on the net right while I was trying to get the car dyno'd!
Old Aug 21, 2008 | 08:33 PM
santomen's Avatar
Thanks for the reply but I guess I'm doing something wrong cause I can't get it to work. This does work for a 04 sl600 right??
Old Aug 21, 2008 | 09:38 PM
'06 SL600
What part do the instructions fail? Are you able to get "dyno" mode up on the screen? Do you get the screen before that? Did you make sure to have the screen set to the "odometer" when you started the process?
To debug, it will be good to know at what point you stopped seeing what the instructions said you would see.
Old Aug 21, 2008 | 09:55 PM
santomen's Avatar
at the very start it doesn't change from temp or miles on car.
Old Aug 21, 2008 | 10:15 PM
'06 SL600
Sorry to sound so simplistic here, but I just want to make sure everything is in order.
1.) Do you have the odometer on miles when you start? (that's where mine was)
2.) You put the key physically into the ignition and just turn the very first click position? (I think there are 2 click positions before the third which starts the car).
3.) At this point, you should see: "UB: 12.0 V"
If not, maybe there's a problem. It seems to work across platforms since it works similar between the E63 and the SL600. Here's a video (posted by a forum member...):
http://www.youtube.com/watch?v=K3D1yvH9T98
Old Aug 22, 2008 | 12:26 AM
santomen's Avatar
it's on miles, key is in first click, press reset button 3 times nothing changes??
Old Aug 22, 2008 | 07:14 AM
'06 SL600
yuck. Last question is "how quick" do you press th reset. Supposedly you need to do all 3 in rapid succession.
Old Aug 22, 2008 | 08:50 AM
armadillo's Avatar
2006 SL600
I don't have a positive answer here, but in some of the other MB series the proceedure for dyno mode changed in pre 2005 year cars, if you do a dyno mode search it should give some info on earlier year dyno mode or if the cars manual if available I would check it if this method does not work.
Old Aug 22, 2008 | 09:43 AM
jmf003's Avatar
'03 SL55
The "three tap" method does not work for my '03.
Instead of tapping reset three times I have to press and hold the button for what seems like forever but is probably 30 to 45 seconds.
Old Aug 22, 2008 | 10:43 AM
armadillo's Avatar
2006 SL600
here is one of the links to dyno mode operation:
https://mbworld.org/forums/showthrea...ight=dyno+mode
Old Aug 22, 2008 | 11:04 AM
'06 SL600
I found this one on the forum...
https://mbworld.org/forums/c32-amg-c55-amg-w203/201412-dyno-mode.html
It looks like it might work with older vehicles. Worth a shot, I figured...
Old Aug 22, 2008 | 08:04 PM
santomen's Avatar
would a malfuction code stop this from working ?? It's shows sos & tire pressure malfuction!!
Old Aug 22, 2008 | 09:33 PM
santomen's Avatar
well it work!! reset the tire pressure back to factory useing the reset button then tried it again turn key to first click screen shows miles/temp push reset button 3 times real fast screen shows ub 12.3v then use the arrow to go to dynometer use the + button to turn it on. I REALLY WANT TO THANK ALL YOU GUYS FOR YOUR HELP!!! THANKS AGAIN! PAT.
