SL/R230: Carlsson C-Tronic Lowering Module Problem. Please Help.
Old Nov 10, 2008 | 07:10 PM
C-three-twenty's Avatar
01 C320 Lorinser Ed.
I recently installed the Carlsson C-Tronic Lowering Module on my 2006 SL600, and I am having a slight problem. Every time the car is in motion, the AirMatic suspension raises the car back up and once I come to a stop, the car lowers back down. This does not seem to be the normal functioning of the lowering module. Has anyone else had a similar problem? If so, could you let me know what I can do to fix it? I have checked the wiring to make sure it is correct and everything seems right to me. Thanks.
Old Oct 15, 2012 | 04:24 AM
ydlee's Avatar
06 CLS500, 07 GL450
Did ever figure out problem? Mine appears to be working except when I park and turn ignition off and lock doors the car cls500 raises to stock height and when I start engine it lowers. My carlsson is v2, I don't know if previous versions are suppose to raise back to stock height when car is parked and locked? Because I thought it was suppose to stay lowered even when parked and only adjust on bumpy roads and speeds over 80mph.
Old Oct 15, 2012 | 01:22 PM
Ekselent's Avatar
SL600 / SL450 (107) / E350 / BMW M5 E60 / BMW 745i (E23) / BMW X6M / Toyota Hilux 4 WD/ Honda CBX 10
Hello.
I have the same lowering module at my SL600 (2004). No problem at al... it's work perfect.
I like it.
Juha
Old Oct 16, 2012 | 12:42 AM
ydlee's Avatar
06 CLS500, 07 GL450
When you park and turn off engine does it raise to stock height? And when you turn on engine does it lower back down?
Old Oct 22, 2012 | 02:57 AM
aaforever's Avatar
W221 S600 // R230 SL500 // B8 A4 // JZZ30 SC300
Try to turn off your ABC using the button and see if that helps
Old May 3, 2013 | 12:02 AM
Zhengyucoo's Avatar
Clk350 SL550 GLA45 GLC63 Raptot
Can you guys help me on how to install it? Please.
Old May 14, 2013 | 10:39 AM
ICanDriveSL55's Avatar
2005 SL55 AMG 32,000Mi, 1995 Lexus Sc400 Pristine
This is just a wild guess, Could you have the wires on backwards ? I am only going from your description and have no expierence with the unit you speak of.
