SL/R230: Brake pad replacement? + brake pad sensor?
Couldn't have been easier.
Still old school like the old Japanese cars.
Will do the SL during the week.
Both cars take the exact same brake pad.
So, that is the second thing that I found that they have in common.
First was the oil filter.
Got the cross-drilled rotors turned down($20) at a machine shop and replaced the brake pads.
Went with cheapo pads - $40 from O'Reilly and $7 for sensor because I will have to replace rotors at next brake pad change.
Bedded in brake pads and it feels good and best of all no Christmas lights on dash.
FYI
You will need an 18mm socket/wrench and a T-30 spline to remove the caliper if you need to take off the rotor.
FYI
How did you change the sensors?
There is a hole in the friction part of the pad that the sensor "pin" goes into and it slots in a groove on the metal piece.
I am counting the savings in not going to the $tealer.
2 x exactly the same brake jobs(C350 & SL500) - over $550 at dealer.
Cost me:
2 x brake pads $83
1 x sensor $7
2 x turn down rotors $20
1 x loctite $5.29
1 1/2 hour total labor time
Cost me:
2 x brake pads $83
1 x sensor $7
1 x loctite $5.29
What was the loctite for?
Loctite was for threads on the 2 x 18mm caliper bolts and the torx bolt that holds rotor onto the hub.
I had the alarm go off because I didn't turn off the anti-tow function(button below ABC switch), but this didn't cause any problems.
What could potentially happen if you turn on the ignition with the caliper off?
I'm no expert, so don't take this as expert advice.
Rook
Rook
So, I thought its time to change the brake pads.
I called the stealership and they told me $20 for diagnosis and 109.50$ for change/axle + brake pad price = so i guess something around $250 per axle.
But they also said, if brake pads are bad I should get a warning message via sensors on the display but I dont have such message on the screen as of now.
I dont want to risk my rotors. Is there a way to check myself without de-assembling the wheels if my brake pads are fine or not?
Also look at the rotors.
Are they glazed, have ridges, high spots or an outer lip.
Dealerships normally will forgo the diagnosis fee if you have the work performed at the same time. If rotors are replaced it does not come out to $250 and you can bet that they going to want to do rotors.
If you looking to spend the $20 wisely and at the same time get brake pads checked, print out the $19.99 coupon from NTB/Tire Kingdom and take it for the wheel balance/rotate/alignment check.
For $20 you get wheels balanced, tire pressure checked, pads and rotors checked, wheels rotated and your alignment checked(I leave this out).
Personally, I wouldn't trust one of those brake job places with the SL. Sure, they're fine for old Tauruses and Silverados but when it comes to brakes on luxury cars, I think they just see a "fat wallet" and pretty much make up stuff to get more money from you. Especially the old standby, "These rotors can't be turned... we'll have to buy new ones for you (at a 140% markup)."
Rook
