SL/R230: SL65 wheel advice please
s600; ford gt
I am finally breaking down and buying an 06 sl65(due to unbelievable prices)and was wondering if I can use old drag radials from an extra set for my 03 S600 to mount on the sl65. I know the wheel size is 19 vs 18 but was curious if it would fit and, if so, if there was any downside to this change.
Thanks for a terrific forum and any insight will be greatly appreciated.
ALL SL AND CLS the off set are different than any other Benz. they will fit but if you look at the car from the back you will notice the wheels sits all the way in instead of having that wide body look ., which means you might need a 20"mm spacers in the back . that's what happen when i tried to fit a set of 20" from my S500 on my SL500 .OTHER WAY AROUND THE WHEELS OF THE SL WILL SCREAM OUT A BIT ON THE S CLASS.
