SL/R230: LOWERING LINKS ?
#101
1 Post
R230
I have literally worked on it a few hours.
I emailed AAR, and John basically did not know, but said it must be something simple............that being said, nothing has been done to remedy. I have removed them numerouse times, reinstalled........but the driver rear is just not changing with any adjustment to the links. It goes up and down to the 3 levels, but I cannot get these levels to adjust........sigh
#102
Nop leave the car the way it is , and after links are installed raise the car to highest setting to reset the system , give about 10 sec and lower the car . to lower your car about 1" all around links should be 3mm longer in front and shorter in back . That gave me more or less 1" drop
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Hm.. So how I understand, when I'll get links. I should adjust it to the same size like originals, then plug it in. In front make it 3mm longer, and in back 3 mm shorter for 1" inch drop?
#103
1 Post
R230
Are you sure on that? Because, once John replied to me that during install it has to be raised... ![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
#104
Yes, a few cycles, each time.
#107
#108
1 Post
R230
Not sure, as reinstalling the stock links is an absolute PITA. VERY difficult to get on and I simply did not have the time yesterday. I will have to remove the nut on the lower arm ball, remove it, attach to the stock link, bolt it back on then use pliers to squeeze the top on.....
#109
#110
1 Post
R230
Yes, the AAR links are very easy, with or without rear wheel on........the stock links take easily 3X the force to get them on, and I simply couldn't while reaching around the disc brake....couldn't get enough force........
#113
1 Post
R230
Max, your one comment intrigues me. Unfortunately my jack will not fit (will have to get on boards first) while the car is at the lowest level. I installed all at the highest level. How would this actually make a difference?
#115
All i said was to install all links , and after all links are in place star the car and raise it to the highest level wait 5 sec than lower the car and you are done .
#116
1 Post
R230
Well, worked on it again for a few hours last night......still no dice with the rears........this is ridiculous......rears do not move....
Even tried the links upside down, did both at same time then raised and dropped, did both individually....etc......![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
I am getting irritated. I have swapped springs and coils, rebuilt at least a dozen motors from crank up, etc.....so am quite comfortable around an auto.......but this is driving me a little crazy.....
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
#117
1 Post
R230
Took some basic advice from John. Just pulled all of the links, caliper verified them back to oem length, installed all, then started up car and backed out into my driveway........guess what......the car is back to normal height!
I think I had a couple of issues.
1) I changed each wheel, then started car and measure height..........a no-no.
2) My garage was less than adequate in terms of level (it is sloped for melting snow run off).
3) I measured what I thought the links should be before mounting.....I should have installed them at oem height, and adjusted while on the car.
4) I didn't have a drink to relax before I started....
Now that I think I understand how the car thinks, I will sequentially drop tomorrow.........whew........
#119
#120
These links are D best way to lower your SL , rcoppens had a little problem with his install , but at the end it turns out just fine and I wouldn't hesitate on buying them again .
#121
I'm still waiting for my links, the delivery is being late, I hope it will reach me... Dieing to install it at last...
#125
SL55 AMG
