SL/R230: Help with engine
Old Dec 28, 2010 | 04:09 PM
pvlexxus's Avatar
2003 SL500, 2005 CLK55
Help with engine
Does anyone know what the little tank above the abc dipstick is? When i twist the cap off it has a meter that says "min 20 degrees max then min 80 degrees max" I've been having trouble with my abc and i poured the hydraulic fluid in the abc deal and i still have problems but when i twisted the other cap off the fluid was on min. If anyone knows please help. Thanks
Old Dec 28, 2010 | 04:43 PM
pvlexxus's Avatar
Maybe it could be the power steering fluid?
Old Dec 28, 2010 | 04:56 PM
pvlexxus's Avatar
can i use the abc hydraulic fluid as power steering fluid?
Old Dec 29, 2010 | 12:30 PM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
NO! They are different fluids. Check your owners manual for the full spec.
Old Dec 29, 2010 | 03:03 PM
pvlexxus's Avatar
Damn, I put like 2 or 3 oz of that stuff in my power steering
the hydraulic oil.
Old Dec 29, 2010 | 03:04 PM
pvlexxus's Avatar
I read that some people say it's the same thing.My manual did not say anything about the abc or the fluid it uses
Old Jan 3, 2011 | 05:16 PM
jctevere's Avatar
2012 C250 Coupe
I don't really know myself, but check out this DIY, it may help you:
http://www.benzworld.org/forums/w215...intenance.html
Old Jan 3, 2011 | 05:40 PM
Lee Wireless's Avatar
1995 SL500 - 2017 AMG GLC 43
ABC-PS same
The ABC and PS fluid is the same type, Pentosin.
Old Jan 3, 2011 | 09:44 PM
pvlexxus's Avatar
awesome thanks. I took it to a mercedes mechanic and he told me my front right strut had gone out. I just got it replaced at the dealership 1 and a half years ago. Not sure what to do now. It's a pretty expensive replacement. I doubt mercedes will cover it since I got it not too long ago.
Old Jan 3, 2011 | 09:46 PM
pvlexxus's Avatar
oh and thanks jctevere, I read that post a while back. It did help, but it didnt fix my problem. It's been a living hell dealing with this issue.
Old Jan 3, 2011 | 09:50 PM
pvlexxus's Avatar
Thanks Lee I feel a lot better, When Ingenere told me it was different I was about to have a heart attack.
Old Jan 11, 2011 | 07:35 PM
pvlexxus's Avatar
I found out my problem, took it to a local mercedes repair shop. They told me what my problem was they said that my left strut is bad. I told him I had it replaced with mercedes a year and a half ago, so he advised me to take it back to them to check and see what they could do. I set up an appointment they want to charge me for a diagnostics to tell me the same info the other place told me and quoted me 2900 for a new strut. I still have the receipt and everything. He also told me I needed to flush my abc, and when I told him I also had that done and I still had the receipt he didnt mention it anymore. Not sure what to do at this point. I had links installed on the car 2 years ago, they later told me that it could be caused from the links and I told him if it was the links they should have told me that was the problem in the first place a year and a half ago so I could put the original back. I guess this basically means I'm screwed and out more money. I got quoted from the local guys for 1700 to replace the strut. I'm so fed up I think I'm going to sell the car cheap and not worry anymore.
Old Jan 13, 2011 | 10:37 PM
djamer's Avatar
SL 500
I feel your pain, man. i sold my SL500 on Jan 1. new year resolution, simply my life and get rid of drama in my life i.e. sell my car which caused me twice a month dealership visits for a host of problems.
Life is short, can't have such hassles..
Old Jan 14, 2011 | 10:56 AM
allimport's Avatar
06 230 chassis
You'll enjoy having this site to learn more about your car and how to keep it going for less money, or , in some cases , relieve yourself of it all together with a new dirrection. (sometimes life is just better without as many headaches) cheers!!
Old Jan 14, 2011 | 02:53 PM
Tobby's Avatar
2020 AMG C63S Coupe, Kawasaki ZX10R
You can get remanufactured schocks here for $499 + core deposit $200: http://www.arnottindustries.com/part...18_pid145.html
Old Jan 14, 2011 | 05:15 PM
pvlexxus's Avatar
Cheers, I'm pretty bummed about selling it, but during times like these I just have to. I've replaced everything that could possibly cause problems for the sl500 and I still run into issues. I've replaced from the shift lever from plastic to aluminum to even replacing the front brakes to the amg brakes. Just so I dont have to run into these problems.
Old Jan 14, 2011 | 05:20 PM
pvlexxus's Avatar
Thanks Tobby, I am debating if I should go for it. I dont think I can install that myself though. I did add the AMG brakes on myself I hope changing out the struts are just as easy.
Old Jan 18, 2011 | 04:07 PM
pvlexxus's Avatar
I just ordered the Arnott left strut, I have my fingers crossed. Thanks!
Old Jan 18, 2011 | 05:01 PM
NeSSuS-GTE's Avatar
Lexus, AMG Soon!
Please keep us posted on your progress. Many of us will inevitably be going through your same dilemma. I have high hopes that the Arnott solution is a good one.
Old Jan 18, 2011 | 06:13 PM
Tobby's Avatar
I think it's a good solution. Much cheaper and they offer lifetime warranty.
Old Jan 18, 2011 | 07:07 PM
edbates2004's Avatar
SL500
Just keep the SL, what else you going to buy a Toyota? Nothing drives like it for the price. Ya the strut went out. Buy a Arnott Strut and find a good local indy and he will install it for $350, so your total should be around $850, well worth the price to drive an SL.
Good Luck, let us know how it turns out.
Old Jan 26, 2011 | 04:18 PM
pvlexxus's Avatar
I got the strut installed, it runs great. My steering wheel seems to be turned just a little to the left when the car goes straight though, but doesn't seem to affect the ride.
I love the SL but I am just afraid that I will run into more problems. Seems like I've replaced everything I that needs to be replaced then something else comes up.
