SL/R230: rear window problem
Any body seen this or know what is the cause/fix?
When I closed the door I also noticed that it didn't go up.
I thought something was wrong, but I had forgot to pull the switch up a second time after I had opened the window a little.
And if the rear window is not completely up after you close the door, It wont go back and close after you open the door.
Hope that helps :-)
If you disconnect or the consumer battery loses all power, you have to sync the windows again by pulling up on the buttons for a second.
You may want to try that.
