SL/R230: Starter battery problem
Old Mar 19, 2011 | 09:50 PM
Tobby's Avatar
2020 AMG C63S Coupe, Kawasaki ZX10R
Question Starter battery problem
I have not been been using my car for 3 weeks. I charged both batteries with the Ctek charger some days ago.
Today I took my car for a short trip. After starting and stopping the car 3 or 4 times it wouldn't start. Tried several times, the engine turned very slowly. A friend came with jumper cables, and I tried once more time before connecting the jumper cables, and suddenly the car started as the battery was charged. Did not make any sense.
Then I drove for 5 min. and stopped again. Tried to start, no luck, the engine just turned slowly. Had to call friend again, the car started right away with cables.
I drove home and connected the Ctek again. The battery charged for a couple of hours before it was 100%. After charging the car started ok. I took it for an 20 min. drive to test. When I came home I stopped the car and tried to start it again. At first attempt it started, at the second attempt it couldn't start. Had to attach the Ctek again.
This is very confusing. I get no display messages. It almost seems like the car wont start when the engine is warm, only when it's cold. Is this a defective battery, or could something else be wrong like the starter?
Old Mar 19, 2011 | 11:14 PM
JackStraw's Avatar
2005 SL600, 2011 Honda Odyssey Touring Elite
How old is your battery?
You have an '02. If your battery is the original, you need a new one.
Old Mar 19, 2011 | 11:32 PM
Tobby's Avatar
I don't know the age of the battery, but it look like it as been there for a while. I think it's strange that I can charge it with the Ctek and that it discharge so fast.
I'm not sure if it will solve the problem or not, but I'm going to pick up a new battery from Mercedes at Monday.
Old Mar 20, 2011 | 05:45 AM
sifis's Avatar
2014 SL550
A new battery will solve your problem. If it does not solve the problem, check the alternator.
Old Mar 20, 2011 | 10:39 AM
Tobby's Avatar
I hope so. But could the alternator be the problem just for the starter battery? The battery in the trunk charges ok.
Old Mar 20, 2011 | 11:24 AM
sifis's Avatar
2014 SL550
I believe there is one alternator for both batteries. Therefore, the starter battery is the problem.
Old Mar 20, 2011 | 02:49 PM
deliman's Avatar
2005 SL55 2000 CL500
The R230 Starter Battery normally lasts about 4-5 years. Maybe less if its not driven regularly. Call Roadside Assistance and they will come out and test the Battery. After they show you it has a cell thats bad they weill replace it for you righjt then and there. Normally about $ 150.00 Installed. Roadside is free for the life of your car. Use them. Its cheaper than the Dealer. And about the same as DIY.
Old Mar 20, 2011 | 03:11 PM
Tobby's Avatar
As my car is a 2002 modell I guess this is the second battery who's gone bad since the car was new. The car has not been used much since last summer because of the winter. Maybe 300 km over the last 6 months. But I have charged both batteries 3 - 4 times. I'm not sure if the Roadside Assistance work the same way here in Norway. I will check it out tomorrow. The battery retails for prox. $ 450 at my local MB dealer
Old Mar 21, 2011 | 06:52 PM
Tobby's Avatar
Got a new battery installed today. Solved the problems, so it was the battery who was gone bad. So now I'm ready for the summer
Old Mar 28, 2011 | 08:41 AM
lippu70's Avatar
2015 mercedes E63 AMG, 2002 Rolls Royce LOL, 1997 Mercedes 300 TD
On the SL when the starter battery will not turn you do not need jumping leads just turn the ignition key to on position for a few seconds than turn to engage the starter and it will work.
Old Mar 29, 2011 | 02:53 PM
Tobby's Avatar
Is that some kind of emergency procedure using the consumer battery if the starter battery goes flat?
Old Mar 30, 2011 | 06:11 AM
lippu70's Avatar
Tobby yes it is only as emergency but it will start your car.
