SL/R230: Update for SL COMAND?
Old May 23, 2011 | 09:11 AM
Sgooter's Avatar
'14 E350, '03 H-D FXDL
Is there a special CD/DVD disc available for updating the COMAND firmware for a 2006 SL500?
I recently installed the 2010 Navigation DVD; however, I thought with this nav disc update I would now see the destination ETA at the bottom of the COMAND display, but it's same limited info as before. That is, I thought the new nav disc would also update the COMAND system, but it appears that nothing has changed except updated map data.
Old May 23, 2011 | 10:42 AM
Cartronics's Avatar
Former Vendor of MBWorld
05 CL65 AMG, 07 Ferrari F430, 03 Range Rover HSE
They only update the map data.
Old May 24, 2011 | 03:50 PM
NCE500's Avatar
2007 E63, 2006 C55
Re: Nav Update
Your MB dealer can update the COMAND firmware to the later versions. I had mine updated last year as it would not load the 2010 map. Big improvement, with more features. I recall they charged me about $100 to do it.
Old Jun 1, 2011 | 11:32 AM
paulrez's Avatar
SL500
My local MB dealer told me the firmware is updated anytime you bring the car in for standard servicing.
Old Jul 24, 2011 | 08:00 AM
geharmon's Avatar
2014 CLS550, 2009 SL550
2011.2 Navigation Update problems
Hopefully someone can help. I have a 2009 sl550 and just purchased the Nav update, version 2011.2. from Navteq. Following the directions (on both the DVD and the Comand manuals) I inserted the DVD into the DVD player and after scanning, the message is that the dissk are unreadable. Am I doing something wrong or are the disks damaged? Thanks in advance,
George
Old Jul 26, 2011 | 07:17 PM
DANB515's Avatar
2005 SL500 2012 GL450 2008 E350 4MATIC
Thanks for the info, I am planning to get it done, will posts results.
Old Jul 27, 2011 | 01:01 AM
Sgooter's Avatar
George
The latest NavTeq DVD nav disc for your SL should have the following part number on the disc label: U0044-0070-005.
The last time I updated my nav disc, the player wouldn't read it, then would not read the previous disc version either, so I took it to the dealer. They could not ID any problem (other than it wasn't reading any discs), so they simply disconnected the player's power plug for about 5 minutes, then reconnected the power plug, which fixed the problem. Go figure.
