SL/R230: Tire Iron Needed
It seems the lugs are 17mm, and a socket will fit in there, but I'm a little hesitant to try to pull the lugs off with a regular 3/8" drive socket. I see that going badly.
You do not need a tire iron, that is used for taking a tire off a wheel.
I torque my own lugs so they aren't overtightened. So I can use a 3/8" drive socket.
If you are removing wheels for the first time and they may be too tight, I'd recommend a 1/2" drive socket. And use a 18" or 24" breaker bar. You can hold on to the fender with your hands (so you don't fall) and jump on the end of the breaker bar to loosen them.
Works perfectly.
