SL/R230: Do I need spacers with these rims?
'05 SL500, '10 750Li
Size: 18x8.5 Front / 18x9.5 Rear
Bolt Pattern: 5x112
Finish: GunMetal Machined Face
Offset: 35 Front / 35 Rear
Hubcentric
Thanks guys
Bolt Pattern: 5x112
Hubcentric
Thanks guys
Several MB's Superperformance MK III Cobra
Ok , so the stock offset is 30mm front and 33mm rear, would not a 5mm spacer and a 2mm spacer make these wheels fit like stock?
Anyone here mounted a 35mm offset wheel on an R230?
Offsets are less than 1/4" off stock so that shouldn't be a problem.
As long as the barrel of the wheel is wide enough to clear your brake calipers you should be fine.
