SL/R230: How to Remove Gas Pedal?
I'm trying to remove the gas pedal from the SL to install a sprintbooster unit for it... But I'm having trouble removing it. How/Where on the gas pedal to we loosen to take it out?
there is a cover over the nut holding the pedal to the floor. at the bottom of the pedal remove the cover and should be at 10mm nut remove the nut then the pedal should swing up and unhook, will have a connector at the top.
