SL/R230: Oil residue on Coil Packs?
Old Mar 27, 2012 | 09:19 AM
Jay04SL's Avatar
2004 SL500 // 2015 S550
Hi everyone. I'm new to the boards, as well as the SL500. I recently picked up my 04 and am loving it so far.
I did have a question - I noticed what appears to be oil residue on top of several of the coil packs. On some of them, it has dripped off the packs down onto the exhaust manifold, although I do not smell oil burning. I know these cars are not coil-over plugs, so I wasn't sure where the seepage could be coming from. Perhaps the valve cover gaskets, but how could the oil travel up the cover to the packs?
I did a search and couldn't find anything specific to this, so I welcome your thoughts and experiences.
Thx.
Old Mar 27, 2012 | 09:32 AM
Jay04SL's Avatar
Well, I just found a pic of a new coil pack, and it appears there is a gasket on the underside, which would indicate an opening on the valve cover to the packs? If so, I wonder if I can just get the coil pack gaskets to replace the leaky culprits.
Old Mar 28, 2012 | 09:16 AM
Jay04SL's Avatar
OK, took a closer look last night. Appears to be residual oil leaking down onto the coil packs from faulty valve cover gaskets. Will replace those and see what happens.
Old Aug 9, 2020 | 03:08 PM
_rodeo_'s Avatar
03 SL55 AMG
Seems facing same exact issue on my SL55. Did the valve cover gasket replacement work out for you although I know it's an 8 yrs old thread.
Old Aug 11, 2020 | 09:16 AM
Jay04SL's Avatar
wow I've had this car for 8-years! Ha. Yep- the valve covers worked. I do recall having to use silicon for the small what seem to be inspection covers. Least back then my gasket kit did not come with those. Let me know if you have any questions.
Old Aug 11, 2020 | 11:31 AM
_rodeo_'s Avatar
03 SL55 AMG
Thanks for the reply.
Inspection covers? What is it? I ordered an epoxy like the picture. Is that what you referring to?
