SL/R230: 2007 sl550 vibration question
Old May 5, 2012 | 08:14 PM
RMBMW's Avatar
sl550
Hello all! I am purchasing a 2007 sl550 from a dealership. It has 46k miles. It looks good, except when in drive at 0 mph the door/car is vibrating. When we asked the dealer, he said it was normal as v8 engines normally vibrate. Is this normal? IF not, what is the problem? Thanks!
Old May 6, 2012 | 06:24 AM
geharmon's Avatar
2014 CLS550, 2009 SL550
No.
Old May 6, 2012 | 10:40 AM
Gsqrd's Avatar
04 MBZ SL500
mounts?
engine/xmission mounts fail often
Old May 6, 2012 | 10:50 AM
RMBMW's Avatar
sl550
Thank you for the replays! So, is replacing the engine/transmission mount a big problem?
Old May 6, 2012 | 12:19 PM
Gsqrd's Avatar
04 MBZ SL500
mounts
mine were done under warranty..usually involves lifting weight off of drivetrain, then unbolt/remove/reattach each mount(3)?
