SL/R230: SL550 knock sensor
Old Aug 16, 2012 | 09:39 PM
cbh1030's Avatar
09 SL550
SL550 knock sensor
Does the SL550 M273 motor have a knock sensor? Ive taken off all the tubing/MAF from the throttle body and searched all around that general area and see only what appears to be a water temp sensor that goes into the block. Also there is a wire grouping that goes to the center of the engine under the intake manifold to something unknown. Is it possibly lower on the block by the mounts? Any advice-Thanks
