SL/R230: Roof is leaking???
I think you may have been extremely lucky if your roof has been operating properly, without any problems so far. This is because the valves need the oil to operate and any leak in any component would cripple the whole system. As you loose oil, the roof hydraulic pump (in the trunk) will soon run out of oil and eventually burn out. That would be very expensive.
Unfortunately you have to track down the leaking valve and replace it. I survived it. I'm sure you will
. Best of luck
