SL/R230: R230 Vario Roof - Trunk hits / drags across tail light
Old Sep 29, 2013 | 09:00 PM
number_one_c55's Avatar
2017 G63
Question R230 Vario Roof - Trunk hits / drags across tail light
I recently purchased a 2003 SL500. I noticed when operating the vario roof that the left side of the trunk when tilting up touches the left side tail light. It is almost as if the right side is opening before the left side thus going close / touching the tail light. I know another person with a 2005 SL65 AMG with the exact same problem yet no one seems to have an answer?????
Old Oct 4, 2013 | 12:52 PM
Bigsnake's Avatar
MB SL500 R230
I think you have to adjust the left sides stopsscrew. It sits under a cover plate on the left side inside the bracket for the tailgate. It is an M8 with a 13 mm head and a 13 mm locking nut. You just need to unscrew it a half a turn to the left. You can check the setting by measuring the gap between the rear fender and trunk. It must be the same on both sides.
